same at me…
For rover select:
TCP Client.
in opt: Adress 102.168.43.24 Port: 2000
Format: u-blox
Receiver commands are done by reachview!
In Options/Postitions: Select RTCM Antenna Position when you use your own base station with rtcm.
if you are also get raw data from your base you must switch to settings/positions and lat/long/heigh and enter your base station coordinates.
at reach:
under : /usr/bin/RTKLIB/app/rtkrcv you can find rtk.conf = configuration file of rtk and ubx.cmd = receiver commands.
booth files are under controll of reachview and rewritten every time you change something in reachview.
Andreas
Hey Andreas,
We would love to get some logs on which we can diagnose your issues. Is that possible?
Hi Egor! Here is one older data set. with heavy testing i had brick my mcx cable connector
from tw 3710 to reach.
therefore at the moment i removed my base…
reach.zip (1.9 MB)
it´s in the next post
