Question, I’ve set the Reach M+ to 10hz GPS only (Rover) in the Reach View software, however the NMEA sentences output are only arrving at 1 Hz through the serial port?
I’ve used loads of expensive RTK systems in the past and never had an issue.
Can anyone tell me how to get 10Hz positional information out of the Reach M+ in Rover Mode?
Please test it outdoors as @timd1971 suggested.
If Reach has no solution status, it outputs the NMEA string with 1 Hz frequency independently of which update rate you specified in ReachView.
