Getting Started
maybe this will save 1000 words :wink:
We do not use a ground plane on the LoRa antenna. Sometimes you can tilt or rotate the antenna to get better reception.
If this is not good enough and you want superior reception over the LoRa radio link, then you could remove the provided antenna and install an extension cable and a different antenna which is deigned for use with a ground plane. Like this:
lora_external_antenna
