Do you know the position of the base when you used it in RTK mode?
You need to know the coordinates base used before and after
Hey guys,
Let’s sum this up.
Unfortunately, there’s no way to fully recover the data for the PPK survey if the raw data log on the rover was not recorded. It’s not possible to post-process survey points collected in Single solution.
However, if there is a way to post-process the base coordinate, it’s possible to calculate the offset between the base coordinate used for the survey and the post-processed one by merely finding the difference between them.
After that, it’s possible to apply this offset to all of the points collected with the Fix and maybe with the Float solution. Please note that this procedure might not be accurate enough and it could be easier to repeat the survey.
