Good day,
I wanted to reach out and ask a few questions regarding Emlids and Drone based surveying. I’m fairly new to the process and looking to dial in a workflow. I’m not a surveyor by trade, but have been active in the drone capture world for the last 3 years and really looking to improve our data accuracy.
At this time we have two Emlid RS2 units (looking to upgrade to a RS3 and RX), and would like to utilize them with a DJI M300 and M350. This prior work week we have been in the field and have managed to log our base point, send out our RINEX data and have it corrected, shoot 5 GCP’s and have flown a few Ortho flights.
A few questions for you.
When setting up our base (not on a known point) I see the option to enter the antenna height in the logging window. Would you recommend having that height marked in the Emlid Flow app logging section before we start our 1-4 hours of averaging to get our correction? Where we perform our work, we don’t have access to NTRIP or may be quite far from a survey monument.
Secondly, our M300/350s all utilize WGS84. When creating our initial project in Emlid Flow, I made the mistake of using NAD83(CSRS) / UTM zone 11N instead of WGS84 / UTM zone 11N. Our GCP’s were nowhere near our base when checking the data in PIX4D. When the project is created using the WGS 84 coordinate system, will this be applied to the base unit Emlid or will a conversion be required and shall we collect the base data in the correct NAD83 format?
Any insight/help would be greatly appreciated. We are looking to create a workflow utilizing the tools we have.
Thank you.
