Hello!
Can I survey with two modules M+ (one as rover e the other as base)? What setup I need?
Hello!
Hi Angelo,
Welcome to the Emlid community forum!
Yes, it’s possible to use Reach M+ either as a base or rover. This guide from our docs can help you to set up both receivers.
However, the Reach M+ has some limitations compared to field-ready receivers. You need to provide it with proper ventilation to avoid overheating. If you’re going to work in rainy weather, you need to think about how to protect the receiver. Reach M+ doesn’t have protection from water and dust.
Thank you!
