Good afternoon,
My set up is the Reach RS2+ as my base and a Reach RS3 as my rover. New project in upstate South Carolina. To begin, I set up the base and logged into the South Carolina RTN network to establish a known point. Measured the point in my project for 15 min, averaging FIX. From there, I set corrections input to OFF and set my base output to the EMLID Caster NTRIP and configure my base by selecting the point that I measured in the project. This will show a SINGLE solution, which you would expect.
After this is done I turn on my Reach RS3 and set my corrections INPUT to the EMLID Caster NTRIP. Here is where I am running into an issue. On other sites, using this same workflow, I am able to get a FIX on my rover and then shoot in some other control points or stake out points input from Emlid Flow 360 on my desktop. But, on this site I never see any better than a SINGLE solution. At this point I am lucky because I don’t need centimeter accuracy as all I am doing is locating all sewer manholes on site for test digging purposes. I am concerned that when I decide to conduct drone surveys that I will not get centimeter accuracy. Any thoughts?
Any input would help. Can anyone see flaws in the workflow that I am missing?
Thanks,
Chris Greene
Bullseye Construction, Inc.
Charlotte, NC.
