I would like to know what is the default coordinate system for the posion logs?
Also what every colum in the position log file means.
I copied one line from a posion file as an example:
2021/07/27 08:32:25.399 4443112.2114 3087066.4664 3366523.3873 1 17 0.0031 0.0100 0.0138 0.0000 0.0000 0.0000 0.40 6.2
The default coordinate system in the position log is WGS 84.
As I see, your position log is in XYZ format. In general, it’s a simple text protocol for coordinates and RTK solution status. It consists of the following columns: time, receiver position, quality flag (RTK solution), number of valid satellites, standard deviations, age of differential, and ratio factor.
