CUT-FILL incorrect (bugged) to linework/points (but surfaces correct)
John, you can see real-time elevation in feet if you scroll the panel with coordinates to the left.
Thanks for the tip! That will help. If you can correct the software so that it will also display feet in the status screen that would be good too. I use the app for quick grade shots when I don’t need to start a project.
Being able to take a few quick grade shots in feet by taping on the status screen would be very convenient. In the mean time, I will use a project to have that ability.
Thanks again, Igor!
In your screenshot, I see “Virtual Reach”. Is there a way to enable that? :wink:
I found it… :wink:
Tap “Receivers” a bunch of times (10). EDIT: (Or “Survey” or “Profile” too)
Takes me about 10 taps to put a peg in too :stuck_out_tongue_winking_eye:
Edit: Seems like this debug tool isn’t in the iOS version.
Hi John,
Do you mean by the status screen is this one?
The cut and fill will also shown in feet if you set your linear unit in feet:
Let me know.
Yes, that is the screen I was referring to. Thanks for your help!
Hi John,
I see, thanks for confirming. I’m going to note yours as +1 to this feature request.
We don’t have it planned for now so I can’t give you any ETA. However I will get back to you when I have any updates regarding this!
