I am trying to establish known point in Penryn, UK by EmlidReach. I was trying to process my data with AUSPOS and RTKLIB, but both of them have not shown me any result. I do not really know what’s the wrong in my data. This is my first time using EmlidReach, ReachView, and RTKLIB, so please would you explain in details what I suppose to do in order to process data. I would be very grateful if anyone could assist, or inform me if I did anything wrong according to the brief description, below.
This is brief details about what I have done in the field: This is just a pilot experiment, I used EmlidReach RS+ to establish one Ground Control Point. I set a tripod and rover (I have Not used base receiver; only rover was used) at unknown points, I checked that Data type is set to RINEX2.11. The point was measured more than 2 hours. Then, in the office, I transferred the data from ReachView app to my laptop. I received 7 files for the same point. After checking that file names are not contain spaces and Antenna type is LEIAX1203+GNSS None, I submitted them to AUSPOS. However, the data has not been processed, it is written that (AUSPOS has experienced an unexpected error, and has been unable to process your data).
Then, I used RTKLIB to post process data, I followed the instruction in EmlidReach Document (I set the mood to static; chose rover .obs fileRINEX file; output: I put rover .Inav file, lastly, I press “Execute” in the main window; and I waited until done label appeared). However, I have Not seen something similar in my output folder, the file with __event is Not contain the geographic coordinate of the measured point, not the accuracy, as shown in the attachment.
BTW:
I want to establish base station in order to measure other points by rover depending to the known point (RTK method)
*The measurements took a place in 14/11/2018 from 10 am to 12:45 (2 hours and 45 min), I am trying to process the data from 20th November and I am still trying to find out the problem.
*I will definitely repeat the measurements when I know the issue in the current one.
Thanks Myozone, but my data (the one point that I measured by rover receiver) is not processed with AUSPOS nor with RTKLIB, I do not know whether I did something wrong or not.
Your link to your UBX files didn’t work because it’s a link to Google drive in general rather than a shared link to your UBX files. Also I’m not sure if AUSPOS will process single frequency L1 data alone, looking at the AUSPOS website it mentions dual frequency, I could be wrong of course, having never used it.
Hi Israa, Your UBX file does process(I used camo reference station data located at Camborne) but it appears to have a lot cycle slips(red vertical dashes) which may indicate you were in a poor location?, also your file is dated 16/11/18 rather than the 14th. Was the rover moving ?.
Dave.
And I also checked. OS is a free service, GNSS Solutions is free for L1 which is completely sufficient. I’m giving the report. It is a preliminary alignment because you have to combine hourly files, add a third reference station and choose a frame of reference.
Regards
PS. Ordnance Survey has developed a detailed web page, but they forgot about the Active Geodetic Network map Report_of_adjustment_preliminary_ik281.pdf (442.0 KB)
Ryszard, They took GNSS Solutions down from being free back in Aug 2018. You have to get someone to send you the setup file because it can not be downloaded from anywhere now.
At least that is what I found about 2-3 weeks ago.
PPP method with single Reach device will not give the result you need for using it in the future as a known point.
At the moment you have the following situation:
If you don’t have the second Reach, the best workflow will be the one, @wizprod and @myozone proposed.
You need to download RINEX file of your nearest station and use it as a base to post-process.
