Is there a way to connect via Bluetooth my RS2 rover to my Trimble TSC2 running the Survey Pro v4.2.1 program? I’m trying to use the corrected output from the RS2 rover’s position streaming using bluetooth. Are there Rover modem settings that I can plug into the Survey Pro for the receiver info?
With our Topcon we were able to connect to Magnet using a Generic NMEA profile. We had other issues after that, but everything was great up until you wanted to shoot a fixed RTK point in which it stalled.
Just search Topcon Magnet" and you will see a few posts.
I had a problem with trimble equipment in general.
It would not pair Bluetooth with anything that does not have Trimble BT. So I couldn’t pair Trimble antena with 3rd party controller, and Trimble controller with 3rd party antena.
Maybe I did something wrong (it was 5 years ago), or maybe they made it that way to lock customers to their equipment only.
I was able to connect thru the Windows BT on the Trimble TSC2. The Survey Pro program on my TSC2 however didn’t have the Emlid devices in its pull down menu for the receivers, so it wasn’t able to connect to receive the data over BT.
We haven’t tested Reach RS2 with the Survey Pro v4.2.1 on Trimble TSC2. To try transmitting Reach position to the Trimble TSC2, you can set the Position output via Bluetooth using the settings from our docs.
To check if the issue with Bluetooth connection can be on the Reach’s side, I’d suggest trying to transmit the coordinates via Bluetooth to one of the apps we’ve already tested with Reach. Please note that for now, the connection via Bluetooth works only if there is a Solution on the receiver.
