Hello. I have a Reach GPS module. When I’m trying to connect to ROMPOS (Romania Position Determination System) to get correction from base via NTRIP a message is display : "Connect error (101)"
Anyone have a idea about this message?
I have to say that I introduce corectly all the parameters to get correction…
Thank you.
What specification does your service provide you with? and what does it need fo it to work. Is should state somewhere on their webpage.
Is it ntrip with VRS?
Hello, I have the same problem.
This is the service: https://www.spingnss.it/spiderweb/frmIndex.aspx
What can I do?
Thanks
I solved the problem!
