ago
(Ago)
July 12, 2017, 10:55am
1
Would it be possible to automatically (using bash script for example) configure Reach module?
For example, I want to set up a rover. So, in order:
first I have to configure wifi network
then I want to set up correction input
and I also want to set up position output
Everything can be done via ReachView (using browser). But how can I do it using bash script?
The web application itself uses probably RTKLIB API? Or where should I start looking for?
Using ReachView 2.6.0.
Thanks in advance!
Not at the moment, but an API for Reach is something that we have plans to add.
ago
(Ago)
July 16, 2017, 8:06am
4
I tried to change configuration directly using RTKLIB, but for some reason it didn’t work.
Then I wrote a small python script which uses socket.io similarly to ReachView web app. So, I ended up with something like that:
from socketIO_client import SocketIO, LoggingNamespace
# define stuff
reach_ip = '192.168.1.100'
reach_port = 80
base_path = '192.168.1.101:9000'
with SocketIO(reach_ip, reach_port, LoggingNamespace) as socketIO:
# correction input
if True:
socketIO.emit("apply configuration", {"correction input":
{"input2":
{"enabled": True,
"type": "tcpcli",
"path": base_path,
'send position to base': "off",
"format": "rtcm3"
socketIO.wait_for_callbacks(seconds=1)
I am using this for the client: https://pypi.python.org/pypi/socketIO-client
The messages to the socket can be found from web app (in javascript). May-be this helps someone. And if someone manages to use RTKLIB directly, please let me know.
system
(system)
Closed
October 20, 2017, 10:55am
5
