So I created a code library named “Granite”
Things worked fine in the field.
Now when I click on the point in EFlow360, it says that the code is not found?
any thoughts
any thoughts
Hi @minotminot,
I couldn’t reproduce the issue on my end. Any codes you create in Emlid Flow should sync automatically with Emlid Flow 360, so this issue seems unusual. I’ve passed it along to the team and will keep you posted on any findings.
As a workaround, I suggest adjusting the code library directly in Emlid Flow 360 to get back on track.
Hi @minotminot,
We’re still looking into it, but to better understand the situation, we need these details:
