Great news here guys I can confirm, something not so obvious when looking at the product pages…
FrSky have released a firmware update for their X4R and X4R-SB compact digital telemetry capable receivers, enabling BOTH CCPM and SBUS side-by-side.
It’s just a firmware update (no special cable needed, just the usual one for flashing) with two pins shorted to enable the functionality. There is no need to switch on or off later then. Once enabled, PWM port 4 remains SBUS (no worries there), but port 1 changes to CPPM. If that was not enough, ports 2 and 3 are STILL available for direct separate use so you can have a total of 10 channels on Navio+ with this receiver!
Of course with Navio 2 this is not necessary as we now have SBUS native support. But this little receiver is now a great choice and if you already installed the SBUS to CPPM converter you can remove it after the update to simplify your wiring.
Just one point of caution, the new LBT firmware does not work with the old internal module firmware. So you also have to follow instructions (and make/get a special cable) to update the internal module of the Taranis.
Furthermore, there is another new receiver on the market from FrSky. The XSR receiver is basically an X4R-SB with the pin headers removed and a smaller (what looks like a DF13) connector in it’s place. It’s priced about 30 euro on Banggood excluding taxes and shipping so this is now THE best compact receiver for Navio in my opinion (it also has both SBUS and CPPM output on the cable!).
X4R-SB “LBT” firmware: http://www.frsky-rc.com/download/view.php?sort=&down=246&file=Firmware-X4R/X4RSB
Receiver upgrade instructions: http://www.frsky-rc.com/download/view.php?sort=&down=121&file=How%20To-S.Port%20Products
Taranis internal transmitter “LBT” firmware upgrade here: http://www.frsky-rc.com/download/view.php?sort=&down=232&file=Firmware-XJT
Transmitter upgrade instructions: http://www.frsky-rc.com/download/view.php?sort=&down=174&file=How-to%20built-in%20XJT%20upgrade
Flash tool used for both receiver and transmitter upgrades: http://www.frsky-rc.com/download/view.php?sort=Tool&down=115&file=Upgrade%20Lite-S.Port%20Telemetry
XSR product page here: http://www.frsky-rc.com/product/pro.php?pro_id=154
Example at Banggood here (currently pre-order): http://www.banggood.com/FrSky-XSR-2_4GHz-16CH-ACCST-Receiver-S-Bus-CPPM-Output-Support-X9D-X9E-X9DP-X12S-X-Series-p-1031481.html
