Changing port on Reach webserver
Hello, is it possible to change the default 80 port on the reach webserver? I need it on a different port because it is behind a router/firewall.
Corrado
you will find the port number here:
/home/reach/ReachView/server.py
line number 287:
socketio.run(app, host = "0.0.0.0", port = 80)
Thank you.
Not very familiar with Pythin, can i just edit it with nano?
Corrado
no prob.
nano is not installed on Reach, but you could use vim, or you could scp yourself a copy, edit locally, and scp back to Reach.
Hello, used VI and all is good. Changed port to 83 and everything works fine.
Thanks
