If you know your way around linux, then ssh in and kill the reachview process and then run it in your terminal and see if there are any errors. Otherwise all I could suggest is to try to flash the firmware once more.
Maybe someone else here has seen this problem.
p.s. it probably won’t help, but you could clear your browser cache and reload the page.
and below is your official docs. shall i do this ? cause i only do the previous part , that is download the Intel Edison Board Configuration Tool , download the firmware v2.3 beat , install the usb driver, flash firmware. dont do the following apart(below)
Install Intel Edison drivers
Unzip downloaded image
Unplug Reach if it’s plugged in
To flash:
cd into the image directory
Run flashall.bat
Plug Reach in
Monitor progress in the terminal window
Proceed to “After flashing”
The docs are giving instructions for different OS. You are having trouble with flashing in Windows, so I suggest you flash in Linux. And yes, use the instructions as you posted above except:
ssh is a command used in Linux to connect to another computer’s console over the network. Let us forget about ssh if you have never used it before. This is not the forum for learning about Linux.
i only do the procedure of downloading the Intel Edison Board Configuration Tool , downloading the firmware v2.3 beat , installing the usb driver, flash firmware.
dont do the following apart(below)Install Intel Edison drivers,Unzip downloaded image,Unplug Reach if it’s plugged in…
i mean should i do the “dont do the following apart” ? i wonder if the probelm occur cause i dont do that part .
OK, I think we had a communication problem. You don’t seem to have a computer with the Linux operating system installed, and you don’t seem to be familiar with Linux, so it is not helpful to continue discussing it.
You do have a computer with the Windows operating system, so I recommend to reflash once more as per the Windows instructions in the docs. I do not use Windows myself, so I am not able to help any further. I hope someone else will have a suggestion for you.
