Finally got it working thanks to Igor - the step to connect the device (in https://docs.emlid.com/reach/common/reachview/firmware-reflashing) should read -FIRST connect the cable (make sure it’s the original Pisen brand and the device is off) and THEN turn on the device when you get to this stage. It should then process the flash.
Thanks George,
We’ll fix it
Hi
I seem to be having same issues as you… log during flash attached. HWat was your final solution?? Many thanks!
JP
FlasgLog.log (72.7 KB)
