I am trying to build OpenVPN directly on Reach following the manual:
https://community.openvpn.net/openvpn/wiki/BuildingUsingGenericBuildsystem
Compiling fails with the following error:
Can't locate integer.pm in @INC (you may need to install the integer module) (@INC contains: /etc/perl /usr/lib/perl/site_perl/5.20.0/ /usr/lib/perl/site_perl/5.20.0 /usr/lib/perl/vendor_perl/5.20.0/ /usr/lib/perl/vendor_perl/5.20.0 /usr/lib/perl/5.20.0/ /usr/lib/perl/5.20.0 /usr/local/lib/site_perl /usr/lib/perl/5.20.0 .) at asm/sha1-586.pl line 667.
BEGIN failed--compilation aborted at asm/sha1-586.pl line 667.
Makefile:46: recipe for target 'sha1-586.s' failed
make[2]: *** [sha1-586.s] Error 2
make[2]: Leaving directory '/tmp/openvpn/openvpn-build/generic/tmp/openssl-1.0.2l/crypto/sha'
Makefile:88: recipe for target 'subdirs' failed
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory '/tmp/openvpn/openvpn-build/generic/tmp/openssl-1.0.2l/crypto'
Makefile:287: recipe for target 'build_crypto' failed
make: *** [build_crypto] Error 1
FATAL: make openssl
Does anybody know how to install the perl module integer on Reach Edison? Or compile OpenVPN?
