Battery Management
Emlid Team,
What is the suggested battery management charging for the RS3?
When to recharge?
Charge everyday regardless of battery state.?
Wait until the battery is at a specific level.?
thanks
boston
Hi Boston,
Reach units use a LiFePO4 battery, which is pretty low-maintenance. Still, a few good habits:
  • You can charge it anytime—no need to wait until it’s low
  • Try not to let the battery drop below 20–30% too often
  • Charging daily is fine if you’re using it regularly
If you’re putting the unit aside for a while:
  • Charge it to around 60%
  • Power it off (hold the power button for 3 seconds until the LED goes out)
  • Store it at room temperature
  • Recharge every 3 months to keep the battery healthy
Good advice, thanks
