Hi Guys, After applying base shift should your typed in coordinate and your survey coordinate be over each other when you view it in your map?
Hi Dennis,
Welcome to our community!
Base shift affects only the data collected after applying it. If you collect the same point before and after applying the base shift, the two locations shouldn’t be the same. Did you experience it behaving differently?
