Hi, I am using emlid M+ with an antenna. In the ReachView, I can see signal. How, all position information are 0. Why?
Hello,
You should have at least a Single solution to start seeing the position.
There is no solution at all, Please see the picture here http://artlystyles.com/tmp/IMG_0443.PNG Is this a hardware problem?
The SNR values are really low, could you try give it a better visual placement outside (Less skyview blocked)
Looks like you are inside. Try placing it in a window, and even better, if you want to have a trustworthy RTK-fix, go outside.
Hi @AutoCar,
You have a “No solution” status because all the satellites have a low SNR value. Usually, it’s related to poor sky visibility. Could you please provide the Reach M+ antenna with the clear sky view and share if it resolves the issue?
