Adjust base location of RTK points when raw rover log is missing
I often record points in locations where there is no known reference point for the base station. My typical workflow is to set up my base on site (over an unknown point) and collect points with my rover in RTK with a FIX. I download RINEX logs from a local CORS station and process the base RINEX using Emlid Studio’s Static processing workflow to get the accurate base location. I then use the Stop and Go workflow to process the Rover RINEX, base RINEX, and corrected base location, to get the absolute positions of the measured points.
Unfortunately, the rover RINEX file is mysteriously missing from a recent survey. I have the base correction file (RTCM3), and a small snippet of the LLH file, but no raw data from the rover (it is particularly strange because I have all of the rover data from surveys collected later in the day at other locations). I do have raw data from the base, and the csv file from the survey.
My questions:
  1. Can I get the absolute positions of the RTK points with simple arithmetic (details below)?
  2. If not, why not?
  3. Any ideas what might have happened to my missing logs?
As I understand it, points collected in RTK have high relative accuracy. This means that we know the distances between the points and the base with a high degree of accuracy, but we do not know their exact coordinates, unless we have a known base location. If the base is not placed on a known point, it will record satellite signals for 2 minutes (depending on settings) to estimate its position. The accuracy of this base position estimate is +/- a few meters (SINGLE). I would like to calculate the distance between the estimated base location (used during data collection) and the corrected base location, and adjust the measured points by the same amount to get their absolute positions. Does this work?
Example with made up coordinates (x, y):
estimated base position: (0, 1)
corrected base position: (2, 3)
point A originally measured location: (5, 4)
Distance between estimated base and point A:
5-0 = 5 units in the x direction, 4-1 = 3 units in the y direction
Corrected location for point A = corrected base location + distance between point A and estimated base position:
corrected point A = (2+5, 3+3) = (7, 6)
OR
Distance between estimated base and corrected base:
2-0 = 2 units in the x direction, 3-1 = 2 units in the y direction
Corrected point A = original point A + distance between estimated and corrected base locations:
corrected point A = (5+2, 4+2) = (7, 6)
Details about my set up:
Base: RS+
Rover: M+ mounted on a survey pole
Emlid Studio Version: 1.9
Hi Christy,
Welcome back! Sorry it’s been quiet here.
You’re on the right track with your second approach. Since the rover points are relative to the base position, you can shift them by the difference between its original and corrected coordinates. Just one thing to keep in mind — both sets of coordinates should be in the same system before making the shift. We have a support tip on this topic.
Before diving deeper into that, let’s address the issue with your missing RINEX file. This isn’t how things should work. Could you check the firmware version your M+ is currently using? It sounds similar to an issue we resolved in firmware version 32.2.
Unfortunately, we aren’t able to restore logs from previous instances, so they would need to be collected again. However, if your rover is already on version 32.2 and you’re still facing this issue, we’d definitely need to investigate further. To help me look into it, please share a Full System Report along with the date and time of the specific log. It’s safer to email it to support@emlid.com.
Thank you for your response! The support tip is exactly what I was looking for, but I failed to find the right search terms.
It looks like I am a couple versions behind of firmware, so that probably explains the missing logs. I will send the full system report via email.
Thanks for sharing the report! I’ve checked it and see that the firmware version is 31.8. This is likely why the log is missing. As much as I’d like to help, it’s not possible to restore it. I suggest updating to firmware 32.2. With this version, you shouldn’t have this issue with the new logs going forward.
As for this CSV file, I’ve already sent you the details on how to correct it via email. I’d be glad to help with it, so feel free to continue the conversation there.
I followed your advice and updated the firmware on all of my reach units, including the M+ on my drone that I use to trigger the camera and record time marks. Today was the first time I have attempted to collect data since the update. It was not a success.
When I attempted to start the drone flight, my camera did not trigger. I discovered that the camera control page is now blank except for the last recorded time mark. I soon found this post (Emlid M2 camera option missing after Firmware 30.1). It appears that Emlid simply got rid of a feature that I was actively using. I had a short window of decent weather and I was not able to collect any data today.
My set up is a DJI Matrice 210 V2 with a Sony a6000 camera and an M+ (on an older firmware than the M+ I used as a rover. I think it was 28.1, but didn’t write it down before updating). I used the M+ camera trigger feature to trigger the camera and the hotshoe adapter to record time marks. No, the camera does not have a timelapse feature.
I would appreciate it if you passed along my experience to the developers. I use this feature and the alternatives do not work for my set up. This system worked perfectly and reliably before the firmware update. Why would you remove a perfectly functional feature?
My preferred solution right now is to revert to a firmware version that still has this functionality. Please help so that I am not left with a non-functional piece of equipment.
Hi Christy,
Thanks for the update!
The camera trigger via Reach was removed in firmware version 30, since it was often more complex and required a custom cable. For a more straightforward approach, we now recommend triggering via the autopilot or the camera.
I totally understand how important this feature was for your setup. However, at the moment, there isn’t a way to downgrade the firmware. We always recommend staying on the latest version, as it includes important fixes and updates. This also means that if you encounter any issues, like the one with your previous logs, we won’t be able to help you with them on the old firmware versions, and we do not want this experience for you.
Hi Inkar,
This response is really disappointing. I had a working system. Now it is broken as a result of a this firmware update and you have not provided any help in fixing it.
This experience is exactly why my devices were not kept on the current firmware. Making changes to a working system is always a risk. This experience has demonstrated that firmware updates from Emlid are definitely a risk, can decrease functionality of the device, and there is no going back if a firmware update causes a problem.
If Emlid wants to encourage its customers to stay on the latest firmware, you need to show customers that we can trust updates not to cause irreversible problems. As a result of this experience, I now consider Emlid firmware updates to be extremely untrustworthy.
Clearly there are not many customers who use this feature, and it was difficult to support on your end. However, it seems like the company could have simply stopped advertising the feature, while leaving it in place for the people who were using it successfully.
Prior to this experience I regularly recommended Emlid products to colleagues. Now I will warn people that firmware updates can remove features that were present at the time of purchase and cannot be reverted.
Hi Christy,
Losing a feature that was key to your setup is not the experience we want you to have. I appreciate your feedback and have passed your concerns along to the team.
Removing the camera trigger was necessary due to the complexity and support challenges. However, I see that this change has significantly impacted your workflow, and I’d like to help you find an alternative. I’ve also written you a PM since next step will contain sensitive information.
Maybe we can make it work with an autopilot or a camera trigger method. I looked into setups specifically for your Sony A6000 and found this example. Which autopilot does your DJI use?
