in RV2.2.1 there is the option to add an ‘additional correction’. What is the purpose of this?
I have set my reach up to use local corrections as base correction and a local igs.net ntrip server in the additional slot, but the additional corrections do not appear to be being used in the solution if I turn off the local base corrections.
sIMON
What is the use of :
Additional correction
in reach?
Can i use my own base and a ntrip as additional correction?
What is the avantage …
andreas
Additional correction will be used to receive precise ephemeris and clock correction from IGS. It is not yet working, we will update once ready.
I use it manually, so it should be automatic ?
When you want additionnal correction from IGS, it’s a little bit boring to download the good data. I mean or I ask if it will be automatic to download clock and ephemeris ?
We have plans to make it automatic.
