Both A2 & A3 gives 4.84V
That means that ADC on Navio is working fine. If there’s voltage on these pins coming from the power module over voltage and current measurement channels then it should not show zero.
Please check the power module cables for integrity.
Ok. I will check again.
Now i get
A2: 1.5V
A3: 0V
I think my power wires is the problem.
Top wires - pixhawk pdb power module.red pin 1 to pin 1
Bottom wires - apm power module. Red pin 1 to pin 6
Which is the correct wires?
Turns out that both power modules has different pinouts though. So both wires are not interchangeable. I guess i need to look for other power module to test.
Answer to which one is correct is also dependent on type of connectors and their pinouts.
Hi Mikhail,
I’ve bought the Mauch 100A Hall Sensor Power Module. Here are the ADC tests:
USB Powered
Mauch PM
Still no reading on A3 channel using Mauch PM. USB has though.
When power module is not connected A3 is floating and thus showing some voltage. If you run some current through the power module, at least few amps, do you see a change on A3?
