I just received my RS2 this afternoon and had some questions regarding the reported accuracy.
With a single solution:
In status mode I could see the lat and long and the expected error in m.
Is this generally a valid value?
When I went into the survey mode to create a point, the accuracy was a few mm and then blew out the longer I waited to eg. 0.3, 0.3, 0.9.
With the single solution is there a standard time interval to wait when you would not expect the precision to vary? Or do you just have to watch the values and make a judgment call?
With a fixed solution:
I had values of ~ 0.003, 0.003, 0.005.
I was 6km from a CORS and had great satellite geometry at the rover.
However, doesn’t the precision achieved exceed what the hardware is capable of ie. 7mm+ 6mm (due to the distance from the base)?
Kind regards,
James
