When I was going to start APM, raspberrypi was as follows.
What should I do?
Hello and welcome!
We need a little more information to understand what’s going on.
Does the issue persist after a reboot? Does the corresponding example work?
It’d be also terrific to see the output of sudo i2cdetect -y 1
. The latter helps looking into such problems as it shows the addresses of discoverable devices on the I2C bus.
Thank you for a reply.
This issue persist after a reboot.I tried it many times.I may succeed when I continue about 30 times.
And the following is a result of i2cdetect -y 1
I am Japanese and a junior highschool student,so I am not good at English but I appreciate your cooperation.
No.I use normal raspbian 4.0.9
Should I use Real-time Linux?
Thank you for the advice!
I was successful APM.
Thank you!
