Need help Post-processing configuration for BASE and ROVER
I see your other question isn’t getting answered.
In regards to this one…I would have all satellites systems turned on, although I’m not actually sure if those settings make a difference for logging. You can have them both set at 1hz or 5 hz. You want to log all information you can and let your post processing software sort through the data.
  1. Logging turned on the whole time you are conducting your survey.
  2. Logging turned off except when your pole is positioned vertically and without moving over your ground control point. Each time you turn it on it starts a new log. Each log will correspond to a control point.
  3. That depends…I have done it for just a minute or two but I think best practice is ten to fifteen minutes. Of course, it still depends on conditions.
Do you like reading?:wink: Some of the answers relate to your question. Also, we’d be happy to help you with your rtk settings at some time. Also, the newest version of Reachview has a feature that will make it easier to help you troubleshoot your settings.
