Hi All, just wondering if somebody can help shed some light on how I can get the GPS to work.
I have tried external antenna as well.
I just built the quad tonight and cant get a fix in apm planner or tower.
What is the correct syntax to launch with external antenna? (please update doc with example)
sudo ArduCopter-quad -A udp:192.168.1.101:14550 -B
or
sudo ArduCopter-quad -B udp:192.168.1.101:14550
If I try:
pi@navio:~/Navio/Python/GPS $ sudo ArduCopter-quad -B udp:192.168.1.101:14550
Raspberry Pi 2 with BCM2709!
Init APM:Copter V3.4-dev (e36ead50)
Free RAM: 262144
FW Ver: 120
load_all took 259us
/sys/kernel/rcio/adc/ch255 not opened: No such file or directory0 0 0 ? Q}?HMC5843: Could not detect version
?3?Calibrating barometerƥ? Quz?3?barometer calibration completeеInit Gyro? Qt***
Ready to FLY ? Q?
? Q̉? Q&?? Q?h? Q(?
Q??
Q???
Q??? Q?f? QE?? QvQ? Q?/? Q???3?PreArm: Need 3D FixPreArm: EKF compass variance???
I have compiled SPIDEV python module, when I run example:
pi@navio:~/Navio/Python/GPS $ sudo python u-blox.py
Current GPS status:
gpsFixOk: 0
gps Fix status: no fix
Error! Checksum doesn't match
Current GPS status:
gpsFixOk: 0
Current GPS status:
gpsFixOk: 0
Current GPS status:
gpsFixOk: 0
Current GPS status:
gpsFixOk: 0
^C
If I make and run C++ example:
pi@navio:~/Navio/C++/Examples/GPS $ sudo ./gps
Ublox test OK
Current GPS status:
gpsFixOk: 0
GPS Millisecond Time of Week: 2624 s
Longitude: 0.000000
Latitude: 0.000000
Height above Ellipsoid: 0.000 m
Height above mean sea level: -17.000 m
Horizontal Accuracy Estateimate: 4294967.295 m
Vertical Accuracy Estateimate: 3802755.840 m
GPS Millisecond Time of Week: 2625 s
Longitude: 0.000000
Latitude: 0.000000
Vertical Accuracy Estateimate: 3802768.384 m
Longitude: 0.000000
Latitude: 0.000000
Repeat forever...
Any ideas on what to try next? I use osx and dont have access to windows easily so cant use the u-connect as mentioned elsewhere.
Many thanks Jimmy.
