Hi there,
I’m building a AuduCopter using Navio+ with RPI2. I made some test flights without problem last week, but it not work today suddenly.
The startup_log show “No pigpio interface for RCInput” after 2-3 minutes;
The Navio+ LED light keep on white, no flash;
No data from UDP in Mission Planner
I tried to reinstall the real-time Linux (emlid-raspberrypi2-raspbian-rt-20150401.img) and APM binaries (http://emlid.com/files/APM/apm.deb), but still don’t work.
Is it hardware problem? I don’t know how to trace the issue. Thanks for your advise.
@igor.vereninov Thanks for your reply. I tried two RPI2, but both of them show same error.
I tried to start it manually:
sudo ArduCopter-quad -A udp:192.168.1.15:14550
Raspberry Pi 2 with BCM2709!
socket connect failed
I tried to get data from Navio+, the Navio board is working
Hi @mikhail.avkhimenia and @igor.vereninov, thanks for your support. The problem has been fixed when I reformat the SD card and reinstalled everything again.
Looks like I’m having the same issue… I will try and re-flash the SD card and see if that helps!
Also I’m very interested to see if you had issues after removing the Network and USB ports, as I would really like to shave some weight off this before I end up turning it into an octocopter!
