Corrupt or "zero" Log file size
Hey @igorvereninov, long time no post. Because we’ve been busy using our REACH’s!
First off, the REACH is AMAZING! You guys keep taking it to the next level, which is awesome!
We are having similar problems to https://community.emlid.com/t/log-file-disappered/7412
When using the most recent firmware version we are having some sporadic issues with log files. Sometimes they are getting corrupted and disappear from the log list in the App. We SSH into the REACH and see the LLH file and the zipped .ubx file, but the .zip of the .ubx has “zero” file size. The LLH file doesn’t help us as we are trying to post-process with a RINEX file.
On older firmware versions, where it keeps the raw .ubx file, we can always go back and download the .ubx unzipped. With the new version, there is only the corrupt .zip file and the LLH file :frowning:
Is there a way to turn off automatic zipping of the .ubx files? Or, have it keep the original .ubx AND the zipped version?
Thanks!
Steve
@igor.vereninov @egor.fedorov Are you guys able to duplicate and/or confirm this issue and that you’re working on a solution?
Thanks,
Steve
Hi @cczeets,
Sorry about the delay with reply, we are looking into the issue :slight_smile:
Thanks @igor.vereninov
It is only happening around 10% of the time, but when it happens we lose the log.
If it’s possible to have the option of turning off .ubx file zipping, that would be great!
Best,
Steve
Can confirm the issue. A solution will be included in the next dev release.
Thanks @egor.fedorov for checking into this and I’m glad you could repeat/fix the issue.
This is one of the MANY reasons why EMLID is so far ahead of the competition!
Best,
Steve
