Hi all,
What are the 3 wire cables connected to the PPM encoder from the channel receiver called ?
Is it possible to connect those two devices with single cables ?
Cheers
Hi all,
Cheers
These cables are usually called “Servo cable male to male”:
But you can use the single jumper cables as well, that would also be lighter as you would need to connect only one GND and one V+ (and all signals of course).
